Shingle humps at eave
On some roofs, I’ve seen evenly spaced humps like this located at the eaves and can’t come up with the cause. This inspection is more severe, running up the roof for 2 or 3 courses. When just at the eave and not running up the roof, which is typical, I’ve thought it to be a shingle expansion issue. Both the starter course and the first row of shingles are lifted, with adhesion present between those courses. I’ve confirmed that nails are located close to the eave, in the starter course. Often, it’s on the south side and not the shaded side. This is not an unusual condition on well installed roofs. I’ve asked around and can’t come up with a cause.
Possible causes
Nail pops Which is usually the case that I see.
Or roof deck attachment.
Were you able to see anything under the shingles?
Common Causes
  • Moisture trapped under shingles: Poor attic ventilation or damaged flashing can cause water to accumulate beneath the roof, swelling the underlayment or decking and pushing shingles upward rescreeningmasters.com**+1**.
  • Roof deck movement: Warped, sagging, or water-damaged decking can create uneven surfaces that lift shingles. Moisture absorption in wood sheathing (without the 1/8" gap between panels) can cause linear ridging at seams Engineer Fix.
  • Improper installation: Incorrect nailing height, spacing, or alignment—especially at the eave—can restrict shingle movement and cause buckling rescreeningmasters.com**+1**.
  • Nail pops or loose fasteners: Rusting or loose nails can lift shingles, creating bumps frontierfoam.com.
  • Thermal expansion: Shingles and decking expand and contract with temperature changes; improper fastening can trap this movement, leading to humps
Wet underlayment.
If it’s at the eaves, my first thought would be poor ice/water shield install, or something is causing the ice/water shield to lift, such as moisture getting under it. Were you able to look up and see the condition of the ice/water shield?
My guess is the roofing bundles were frozen when installed ?
Very good point. Thanks! Bundles of frozen shingles are not unusual here. Lots of work is done here during cold weather.
To the other comments; the roof deck is dry, good ventilation with rafter chutes. I know all the typical and possible causes. I keep coming back to over driven nails that restrict shingle expansion.
I’m going to have to corner a roofing contractor I know, next time I see him…
My experience too.
So, what do you guess is happening?
Shingle thaws > then what?? Moisture issue, fastener issue??
I’ve heard that referred to as “fish mouthing”. Lots of potential causes and I’ve heard lots of opinions over the years. Mine is that its some type of expansion/contractor. Whether that’s underlayment, roof decking, drip edge, the shingles or a combination of any/all of those is up for debate.
It expands. If they are installing in freezing weather they should be putting an expansion gap between the shingles. I feel like in most cases of this, you would most likely see lifting in multiple locations across the roof, not just at the eaves. However, anything is possible.
They’re bent/warped and contracted when frozen on install and expand and hump up when warmed up/heated?
Inspection last week had that and it was the drip edge flashing that was buckling due to heat.
Have you lifted the shingles up and looked under them?
This should give you the answer.
Yup: Rolled out (vs 36 or 39 inch) starter course. Good shingle adhesion to the starter course. Good adhesion on subsequent courses. Starter course nailed near the bottom edge of the roof just above the roof edge flashing. Location of nails on subsequent courses unknown because of shingle tab adhesion. Ice/water shield under the starter course. Roof edge flashing properly lapped. Proper ventilation including rafter bay chutes. Energy heel with blown fiberglass, uniform. No signs of roof sheathing moisture (OSB).
This is a condition I see often, although generally only buckling on the first course. It’s typically the south facing roof. The condition that makes the most sense is shingles applied while frozen.
This makes no sense, the south side will get way more sun than the north side of the roof.
As a roofer for many many years, this is most common with sloppy underlayment installs.
