Short Cycling Honeywell Thermostat?
Hi all I am new to this web site just have a few questions about my furnace.
I have a gas furnace, it has a honeywell t8602d thermostat I notice that recently my furnace is cycling more than usual about 3 times within 10 minutes, I replaced the air filter and open all the bents, cleaned the flame sensor but still doing the same. I am thinking I might be the thermostat settings. Does anyone know what these numbers do ? are they for the heat anticipator settings? thanks
Eventually you will freeze your a s s off and come to your senses, then you’ll call an HVAC contractor to fix your short cycling problem.
install manual has the codes & wiring diagrams
http://customer.honeywell.com/techlit/pdf/69-0000s/69-1510.pdf
problems continue contact qualified hvac specialist
