I am building a home and while the house is not done yet I want to either prerun cable for Ethernet/Coax or if I can run smurf tube(ENT) or PVC. So it can be easier to change out later on if need to be.
From reading on some other forums that I cannot run PVC in the walls for low voltage wiring. Is this true?
If so could I run smurf tube(ENT) instead?
Or do the wires need to be bare?
That is correct considering you answered your own question without reading my “moderated post”. Sorry for not being “Professional enough” to meet your expectations.
I thought this was a place to be civil and help out people that is trying to get answers for some that might not know the “proper terminology”.
A large portion of upscale new construction up here run smurf tubing during rough in from the attic to the crawl space, master bedroom, above fireplaces and in custom cabinetry for all the speaker wires, alarms, catv, CAT 5-6 cables. Not uncommon to see 3, 4 or 5 stubs in the attic above the insulation.
