Originally Posted By: bob haller This post was automatically imported from our archived forum.
The NEC is so careul about everything BUT!
You have a 15 amp breaker with 14 gauge wire, so far all is well
But then you plug in a 16 gauge extyension cord that can get abused....
Seems like this would be a obvious fire hazard I have often woindered why the minimum gauge of extension cords isnt at least 14 to prevent troubles where they are most likely to occur to begin with?
Originally Posted By: Greg Fretwell This post was automatically imported from our archived forum.
The assumption is a 16 ga cord will operate a 20a breaker with a bolted fault The problem arises when it is simply an overload (for 16ga wire) that draws less than 20a. More dangerous is the older 18 ga extension cords.
Yep I was thinking of a overladed or partial short. I repair office machines for a living, laminators and see wires that have melted and even burned thru that never tripped a breaker.
In a home ith flmmables around it looks like a obvious failuree mode
Originally Posted By: phinsperger This post was automatically imported from our archived forum.
Also extentions cords are not (should not ) be restricted from disipating heat. If you ran a #16 in an insulated wall cavity and put 15 amps though it, it would heat up nicely
Originally Posted By: bbadger This post was automatically imported from our archived forum.
This is covered by the NEC.
Quote:
250.5(B)(3)(3) Extension Cord Sets. Flexible cord used in listed extension cord sets, or in extension cords made with separately listed and installed components, shall be permitted to be supplied by a branch circuit of Article 210 in accordance with the following:
