Stand alone thermal imaging template
No, not at all. And I see where you are going with this. I have found numerous roof leaks and insulation issues that I would not have otherwise known about. Even some toilet leaks that were not visible.
But I dont charge additional for it, which is why I dont think it changes my liability like it would if I were to charge for being a thermographer.
My agreement also states that it is just used as a complimentary tool as part of my inspection, which adds great value
Thomas its all good I just had a client that had a water leak and couldn’t find it and it was a leak in the attic by the chimney and was running down a rafter and dripping in there sun room. I found the leak first visually and them took thermal reads of the area and then followed up with a moisture, the client was happy and I wanted a simple template to put a narrative in and attach a few pics. I think I will just do a word doc. and add the pics with my narrative and call it go. lol I didn’t see all this coming had two inspections today and one was a flip house…smh
I use it. I just don’t make reference to it in my report. If I see moisture issues, the meter comes out. I just state in my report that potential moisture issues are present and photo the meter results.
but what if your called to assist in a water leak with no home inspection??
I dont use a Flir, but if thats what you have, I believe they come with report software
That is where you need to be further certified. It becomes more “specialized” in the inspection and for your on liability and protection.
Great question. A thermal camera should be one of many tools in the bag. I doubt I would set up a thermal scan agreement, I would just do a component evaluation and use that tool along with others.
I like this statement:
How can you be called to inspect ‘water infiltration’ with a method? Ancillary Inspections.
I do Moisture Intrusion Inspections. I start my fee at $450.00, although the fee can go much higher depending upon the building type.
Look at it this way, every course study in itself is a type of ancillary Inspection. So, If you passed the interNACHI home inspection certification course, and are now a certified professional inspector, you passed a course on Moisture Intrusion.
James, there is a lot you have yet to understand about methods of investigating, equipment, and credentials. Quantitative research deals with numbers and statistics, while qualitative research deals with words and meanings. Qualitative methods allow you to explore concepts and experiences in more detail.
Being a certified home inspector comes with limitations. You expand your field in investigating with learning investigative techniques through additional certifications and course study work.
I hope that answered your question.
I sure wish you guys would quit with the “certification” thing. There is a “TI Certified” classification. So unless your actually certified, your not Certified. The class you take may be “certified”, but you are not. You have to be a Lvl III (+) to get certified. Who here is a Lvl III? Are you certified?
Using that word is a liability should you come across someone who knows the difference.
James, I recommend you contact Jim Seffrin at :
https://infraspection.com/infraspection-institute-master-thermographer-directory/master-thermographer-jim-seffrin/
and get a copy of his inspection standards for what ever type of thermal imaging you plan to do. Make your template based on these industry standards. Don’t use someone else’s template as it is most likely worthless. If you do not want to do that, just make a segment in your home inspection template to cover the thermography you did. NACHI has something along these lines. Check there.
This is what I did. Also, set a very strict scope when creating your thermal inspection agreement. You want your scope to be in-line with your training and capabilities.
Or their Attorney??
You are correct, Dan. It’s an app called ‘FLIR Tools’.
This has always been a contention with you, David where as myself, the educational module is a step moving inspectors in the right direction.
As with any self described term, you can get yourself in legal jeopardy misappropriating a designation, PR misappropriation.
I thought William Decker was updating the IR educational model to be more inline with accredited infrared educational models like Infraspection Institute application courses, Home & Building Inspectors offered at a discount to InterNACHI members I my memory serves me well, and Monroe IR training.
NO OFFENSE BUT YOU KNOW NOTHING ABOUT ME AT ALL, and as a owner a large fire and water restoration company and a retired Chief of Police and feel I have a lot of investigative knowledge. I haven’t just took the cpi course and pasted it I have also took the Ashi exam the NHIE exam and a multitude of courses with InterNACHI I have always believed in furthering your knowledge of the profession or field you are working in.
enclosing we are all members I think of a great organization, and people are quick judge and come across as trying to belittle people, and assume the certificate you got from InterNACHI came from a box of cracker jacks and it a standing joke when someone ask a simple question. I have sent Nick And Ben both emails and ask them to look at this thread and give me there opinion as to some of the replies.
thanks to ben gromicko and the stuff at inspectors outlet for getting me booth supplies of short notice.
Relax, James. Easy with the all caps. You asked the questions.
“I need a standalone inspection template.”
Well, it is not that simple.
I use, note I use, ‘a thermogram’ with a brief description, using Quantitative research layering an image of the ‘moisture metering readings’ I recorded on my Tramex or Delmhorst Techcheck Pro moisture meters.
I know some individuals get very tired and irritable at times while learning. “When in the h-ll will I be able to understand everything and put it all together to start earning money?”
Many here, Been there, Done/Did that.
Take a break and continue on 'a work model ‘that is right for you.’
The old expression is KISS. ‘Keep It Simple Student.’ Actually, James… when I joined the organization the original term was ‘Keep It Simple Stupid.’ Not so polite, is it? So I modified the acronym to be and sound more professional. ‘Keep It Simple Student’
From the information I have gathered, very few inspectors use professional grade thermal imaging equipment. Most use very low resolution to target anomalies. Then other equipment is used to measure the anomaly.
The standard base/minimal thermal imaging resolutions. 160 x 120. Resnet use to be 120 x 120. Then 180 x 240, 320 x 240 and now 640 x 480 pixels and higher with super resolution built into some software.
Good thermographers earn $250,000 annually. You do not make that can of money doing home inspections. David Anderson just happens to be one such thermographer.
James. Take a break from studies. You want the phone to ring and keep you busy.
You will do fine.
I didn’t ask for any advice the topic is does anyone have a stand alone thermal template and if so would they share it…….that’s it.
EVERYTHING has a price, especially if it was created out of the hard work of others!
You want free, go to Facebook and get what you pay for!!
This sentence and the way you claimed to ask (below) are very different.
Maybe the demand stuff (I need a) worked as a cop. You may want to approach what ultimately will be a free gift with some class.
I have a template that I have created for my business.
