Staples in a 3-tab asphault shingle roof?
Originally Posted By: wpoole
Just finished an inspecton on new construction. The 3-tab asphault shingles were installed with staples - not roofing nails! It was amazing to me that this made it through a code inspection! However, just to make sure I hadn’t missed out on a new code approval in Spring Hill, Tennessee, I called codes and was told, “nope, has to be roofing nails!” aiwebs_017.gif
Would like to get some fedback on this one!
Originally Posted By: gbeaumont
IRC wrote:
905.2.5 Fasteners.
Fasteners for asphalt shingles shall be galvanized steel, stainless steel, aluminum or copper roofing nails, minimum12 gage [0.105 inch (2.67 mm)] shank with a minimum 3/8-inch (9.5 mm) diameter head, ASTM F 1667, of a length to penetrate through the roofing materials and a minimum of 3/4 inch (19.1 mm) into the roof sheathing. Where the roof sheathing is less than 3/4 inch (19.1 mm) thick, the fasteners shall penetrate through the sheathing. Fasteners shall comply with ASTM F 1667
Regards
Gerry
Gerry Beaumont
NACHI Education Committee
e-mail : [email protected]
NACHI phone 484-429-5466
Inspection Depot Education
[email protected]
"Education is a journey, not a destination"
Originally Posted By: jpope
Under IRC, fasteners are required to be nails. IRC 905.2.5
UBC allows staples per table 15-B-1
Jeff Pope
JPI Home Inspection Service
(661) 212-0738
Originally Posted By: dduffy
I have had numerous contractors quite infuriated also. Then you also have the contractors using the nail guns, with three quarters of the nails only set half way, and shingles sticking up all over the roof because they will not seal.
City Building inspectors do not go on roofs in Arizona, so builders will try to sneak staples in sometimes. Bad move, especially when they have to go back and pick all the tabs up and nail them as required.
During our summer monsoon season, inspecting roof claims for insurance companies, 85% of the damage, or missing shingles are directly related to staple use. Instead of tabs blowing off, when nails are used, large sections of shingles peel off, staples and all.
Dale Duffy
Inspect Arizona Companies Inc.
Hi Dale,
I agree, I don't know why all codes have not banned staples, I am not sure if any shingle manufacturers still list them as approved fasteners, I believe that certainteed does not.
Regards
Gerry
Gerry Beaumont
[email protected]
Hi Gerry,
I just dealt with the Licensing Agency for contractors in (Arizona), regarding the use of staples on a large apartment complex here in Phoenix by a licensed contractor.
The contractor lost.
That was a big issue, just as you said, the manufactures of the shingle will not warranty the shingle if staples are used.
They also would not warranty the shingles after nails were attached either, because of the damage the staples caused from too much air pressure in the guns, and not a IRC approved method of installation, the state of Arizona, or theirs.
Dale Duffy
Thanks for the feedback. I will update the post as the saga unfolds.
Bill ![icon_rolleyes.gif](upload://iqxt7ABYC2TEBomNkCmZARIrQr6.gif)
Originally Posted By: Jay Moge
staple are o.k. for the sheething up here, but not the staples. they just rip right threw the shingle. i seem to remember this topic once before. icon_cool.gif
Well, I did my job & strongly discouraged my client from purchasing this new home with staples holding the shingles down.
He called me yesterday after he did his “walk-thru” and said he was satisfied with the staples because the builder showed him the packaging that stated they can be installed with them (or nails!).
I did provide my client with a copy or the IRC code & the information I received from the code inspector.
I guess I have done all that I can do…
Bill ![icon_cry.gif](upload://r83gSGUzNOacIqpjVReDwcR83xZ.gif)
