By Barry Stone / Syndicated columnist](http://www.abqjournal.com/author/barrystone)
PUBLISHED: Sunday, December 28, 2014 at 12:05 am
… DEAR BARRY: I’ve been a home inspector for about two years, so I’m still learning. Unfortunately, I just learned a very hard lesson after doing a free walk-through inspection as a favor for a real-estate agent who was buying a high-rise condo. Eight months later, he is suing me because he found fogging between the panes of a large dual-pane window. The controversial window is on the 15th floor, and the cost to replace it is $2,500. The agent had the window replaced before notifying me of the problem, and now he expects me to pay for it. We’re scheduled for small-claims court next month, and I’d like some advice in presenting my side of the story to the judge. – Tim Dear Tim: Welcome to the enervating world of home inspection and real-estate disclosure. Good deeds, as they say, may not go unpunished.
As this is not a legal advice column, I can only counsel you as a layman and a home inspector. Additional advice from an attorney is strongly advised before representing your side of the story in court.
Since you did the inspection as a favor, you probably do not have a signed contract to specify the scope of the inspection or the limits of liability. Nevertheless, here are some effective points that can make a positive difference when presenting your case to the judge:
· This was not a paid home inspection but merely a casual walkthrough, performed as a personal favor, and therefore is not subject to the same standards as a full home inspection.
· You inspected the windows, and no evidence of a faulty dual-pane seal was apparent at that time.
· The agent also did not see the window defect prior to purchasing the property, indicating the defect was not apparent or was nonexistent at that time.
· The agent is alleging the window defect pre-existed the purchase of the property, but there is no way for him to prove that such was the case.
· It is common knowledge in the home-inspection business that fogging between window panes is not always visible, depending upon variations in lighting and temperature.
· The eight-month time lapse between purchase of the property and discovery of the window defect indicates the window seal may have failed after the property was purchased.
· You were never given an opportunity to re-inspect the failed window prior to its being replaced. It is common knowledge among real-estate agents that home inspectors should be called to re-inspect a defect prior to making repairs.
· If the agent appears in court without an expert witness who is a professional home inspector, be sure to point out to the judge that the plaintiff has no expert witness who is qualified to testify regarding the standard of care for a home inspection.
· Be sure to practice your presentation of these points, use notes in court so you won’t leave anything out, and spend an hour with an attorney for additional advice on presenting your case. Distributed by Action Coast Publishing. To write to Barry Stone, please visit him on the Web at housedetective.com](http://www.housedetective.com/).
Exactly… thanks Cameron .
and that is why I post many things to help others see what goes on in the
real world .
There are many out there that want to get things for free.
I wonder what the client would have done if this was a “dangerous” defect not found??, or if someone died due to this “free” inspection as a favor??? Also, it seems this HI did this inspection with the client “knowing” this was a HI (who is held to a higher standard due to the knowledge of that HI). The C of E has nothing to due with $$$$, or with politics. What difference does it make to claim it was a “free” inspection as a “favor”??
