Student Discussion: How to Inspect Pools and Spas Course
The attached photo is of a pool drain that is not anti votex. This is a safety hazard. Drain covers like this should be removed and replaced with anti vortex drain covers. This will help prevent hair getting wound up into the drain.
Fireplace inserts should have a wire mesh flame cage and screen doors installed. The damper should have a damper restrictor or stop installed. The flue should not be sooty - recommend cleaning if they have been using it as wood burning.
Swimming pool water is low below tiles anddeck is missing where inground pool skimmer is leaking and broken. pipes from ground are visual. recommend a professionl pool contractor inspected it. caulking is missing in places around the pool between the deck and coping.
pricing and billing
I learned in the article
that to figure out want i want to make in the year , my overhead and 20%.
To how to make my price and how to bill them for my service. I also learned how to work with another inspector and how the services will be billed. thank you for the article.
To calculate my timehow long it will take to do a home inspection and the driving time the report time all adds up. im looking forward to becoming a home inspector and to give great service to my future clients. I really like to work along with other home inspectors.
I am inspecting a pool motor. It is not very hot to the touch. There are no visible leaks from the motor. The motor is not very noisy or fluctuating in noise. The motor is also bonded to the other equipment.
When I inspect a swimming pool, one thing I will be checking is for a pool drain hazard. I will want to make sure that a drain cover is present and attached properly. I will look for a safety sanp fitting for the ground pool cleaner. I will look for a sfety vacuum release system. If any of these items are not satisfied. I will recommend review by a swimming pool contractor because of a safety hazard.
This is the water supply line into my basement. It consists of the proper components including a pressure valve and to regulate the pressure from the supply, an air valve to allow air to exit, a filter between the supply in and the house appliances, and a flow meter.
As I took the course for inspecting pools and spas, I took a closer look at my indoor whirlpool tub. it has both heater and air just that are internally housed within the structure suspending the tub. I could not locate an opening to access the heater. This is a defect that I will have to have addressed soon.
This is a photo of a pools main drain and cover. As you can see it is not installed properly and as result can be a big safety concern. The main drain can produce power suction and cause someone to be pulled down.
The electrical equipment for swimming pools must be grounded and connected by wiring methods in accordance with the NFPA 70 National Electric Code. An equipment-grounding conductor should be installed with the feeder conductors between the grounding terminal of the pool equipment panelboard and the grounding terminal of the applicable service equipment.
The photo is of a pool pump and a saltwater chlorine generator. All the equipment was in good working order at the time of inspection there were no leaks noted and all electrical components had a external ground wire ensuring proper bonding.
The picture I chose was of a kitchen sink that had a disposer and dish washer. There were shut off valves for the hot and cold supply lines and an additional shut off for the dishwasher. The drain line from the dishwasher had a lop that was higher than the connection it was not visible in the photo but probably went to a air gap valve.
This is a cartridge system pool pump. The cartridge is used to filter contaminants out of the water while the pump is running When the cartridge is clogged the system will not work properly and will need to be cleaned or replaced.
making sure that you have a good inspection checklist when inspecting pools will assure that you do not miss anything that may potentially be a safety concern. Checks and balances in the inspection industry is key to keeping yourself and your clients safe.
I took a photo of a in wall ac unit for my essay. I know during an inspection we are not required to inspect these types of ac units. This ac unit is in good condition and operates very well.
Although inspection of return ducts is not a required step in a professional home inspection, return ducts are a vital component of the HVAC system. Because of this, home inspectors should familiarize themselves with the following key facts and practices in order to perform a superior inspection of the HVAC system.
I recently inspected my personal pool when preparing to upgrade the lighting to LED. My pool is equipped with two wet niche luminaires which were previously equipped with 500 watt halogen bulbs. The lighting circuit is 120 volts and is equipped with the required GFCI protection. The lights are installed at 18 inches below the water line. The photo is with the LED light upgrade. As you can see, even without any exterior lighting the LED lights provide enough illumination to clearly see the bottom of the pool.
I read the inspection article on pool alarms. As a pool owner, I want to take every precaution I can to keep children safe in our pool area, and as an inspector I want to encourage my clients to do the same. Even with a barrier fence and self-closing gate it is still possible for an unattended child to enter the pool area. If this happens, having a pool alarm will alert the homeowner if the child willingly or inadvertently enters the pool.
Per the attached photo, the equipment bonding for the pump assemblies and pool heater was properly installed and verified correct. There were no indications of equipment water leaks. All water lines and valves in the equipment area were properly supported and marked.
Pool Drain Hazards Inspection: I learned from this article that pool drain hazards can be fatal, especially for young children. It is important during a pool drain inspection to ensure all pool drain covers are in good condition and properly secured to the pool.
