Sub-panel bonded?
Originally Posted By: mpettitt
Just need to double check myself.
New sub-panel in detached garage, three wire feed, separate ground rod, 2 hots and a neutral, neutrals and grounds are bonded, is this correct. I hope someone can reply soon as report has to be out.
Originally Posted By: mboyett
Got a photo? Neutral shouldn’t be bonded at a subpanel.
Mike Boyett
Capital City Inspections
Austin, Tx
www.capcityinspections.com
If there are no other metalic paths (plumbing?) you are OK
250.32(B)(2) Grounded Conductor. Where (1) an equipment grounding conductor is not run with the supply to the building or structure, (2) there are no continuous metallic paths bonded to the grounding system in both buildings or structures involved, and (3) ground-fault protection of equipment has not been installed on the common ac service, the grounded circuit conductor run with the supply to the building or structure shall be connected to the building or structure disconnecting means and to the grounding electrode(s) and shall be used for grounding or bonding of equipment, structures, or frames required to be grounded or bonded. The size of the grounded conductor shall not be smaller than the larger of
Mike and Greg, thanks for your quick replies, but if I’m not mistaken you both gave two different answers. I, too always thought that neutrals and grounds should be separated at a sub-panel, but after viewing several other posts on the subject, I am now not sure. What you said Greg is pretty much what I’ve read lately which prompted me to post this message. So, if I’m reading you correctly (Greg) it is okay for the neutrals and grounds to be bonded. Right?
Oh btw, there are no conductive paths to the separate building in question.
Mike,
Go with what Greg said, if you can decipher it. I can’t translate it to English though.
Mike Boyett
Austin, Tx
The short answer is, with no other ground paths you can treat a sub in a second building like a main, run 3 wires and ground the neutral.
BTW a phone line is NOT a metalic path since it isn’t bonded in the second building
Thanks Mike & Greg, this message board is great!
Question: You say "three wire feed." What type of wiring method is being used? Is it a cable assembly, or is it a conduit or tubing and is it metal or nonmetallic?
The quick and immediate answers here are always admirable, and give references that may be accurate according to the most recent edition of the NEC.
Pictures are necessary when these types of questions are asked, just trying to save you from being embarrassed or held liable for making a mistake!
Joe Tedesco, NEC Consultant
www.nachi.org/tedescobook.htm
Originally Posted By: pdickerson
Mike,
Make sure that there is no conductive path between the two buildings. Water pipes, chain link fences, and concrete sidewalks might provide a path for return current through the grounding system.
Joe, you are absolutely right, I should have mentioned that it was plastic conduit. I have to admit that I’ve been struggling with this issue concerning when it is okay for the neutrals and grounds to be bonded in a sub-panel in a separate building. Sorry about no picture, I did attempt one but this was at the end of the inspection and my batteries went dead (ran out of spares). Any further help you can give to clarify some of these issues would be great. Thanks for your reply
Paul, thanks, there were no conductive paths between buildings.
mpettitt wrote:
Joe, you are absolutely right, I should have mentioned that it was plastic conduit. I have to admit that I've been struggling with this issue concerning when it is okay for the neutrals and grounds to be bonded in a sub-panel in a separate building. Sorry about no picture, I did attempt one but this was at the end of the inspection and my batteries went dead (ran out of spares). Any further help you can give to clarify some of these issues would be great. Thanks for your reply
OK, so you are saying that the PVC had only three wires installed, one grounded (neutral) and two hot legs?
Is there a MBJ installed in the subpanel?
Originally Posted By: bbadger
Greg Fretwell wrote:
BTW a phone line is NOT a metallic path since it isn't bonded in the second building
Greg I agree it probably won't be bonded in the second building however I am fairly certain that NEC 830 requires them to be via the primary protectors that are never installed. ![icon_confused.gif](upload://qv5zppiN69qCk2Y6JzaFYhrff8S.gif)
Bob Badger
Electrical Construction & Maintenance
Moderator at ECN
pdickerson wrote:
Mike,
This would only be an issue if the fence or the rebar in the sidewalk was "bonded to the grounding system" at both ends.
This was tossed around for a while on some other boards and that language from 250.32(B)(2) was ciited
Joe, yes that is correct. By MBJ do you mean a main breaker, if so then no, just 4 single pole 20 amp breakers. Here is another thought that may come into play. The separate building, main panel and sub-panel are all modern (appears to be brand new), no other electrical problems throughout home or separate building. The separate building is constructed in such a way as the exterior metal siding is exposed on the inside. The sub-panel is attached directly to this metal siding.
Originally Posted By: rcooke
My thoughts you should only have one ground to a system . If you take a feed out to another building you must also carry the ground with it . If you put in a second ground you can run into what is called Eddie currents.
Years ago I ran into a place where horses would never go between two building and this was the reason .
Roy sr
Roy Cooke Sr.
http://Royshomeinspection.com
Mike MBJ Main Bonding Jumper That is the bond between neutral and ground.
For better or worse this is what happens between any group of homes fed from a common transformer.
Bob Badger
Moderator at ECN
