Originally Posted By: pdickerson
http://www.nachi.org/bbsystem/usrimages/P/P1120939.JPG ]
[ Image: http://www.nachi.org/bbsystem/usrimages/P/P1120941.JPG ]
Originally Posted By: rmoore
Richard Moore
Rest Assured Inspection Services
Seattle, WA
www.rainspect.com
Originally Posted By: bbadger
| Quote: |
| ....no continuous metallic paths bonded to the grounding system in both buildings or structures..... |
Bob Badger
Electrical Construction & Maintenance
Moderator at ECN
Originally Posted By: jpope
Jeff Pope
JPI Home Inspection Service
“At JPI, we’ll help you look better”
(661) 212-0738
Bob Badger
Moderator at ECN
Originally Posted By: rcooke
| pdickerson wrote: |
| Thanks All!
I wish I could remember enough physics to calculate how much current would flow through the water in the pipe. It would be a very simple equation to solve if I knew what value to assign to the water. |
Roy Cooke Sr.
http://Royshomeinspection.com
| jim creegan wrote: |
| Pure water is about 18,000,000 ohms/cm, Tap water can be 11,000 to 1000 ohms/cm for mineral water. (http://www.jp.horiba.com/story_e/conductivity/conductivity_05.htm) Thousands of times copper's resistance.
JimC |
Roy Cooke Sr.
Originally Posted By: Aron Jacobs
| Quote: |
| 200.6 (C) Flexible Cords. An insulated conductor that is intended for use as a grounded conductor, where contained within a flexible cord, shall be identified by a white or gray outer finish or by methods permitted by 400.22. |
| Quote: |
| 250.32 Buildings or Structures Supplied by Feeder(s) or Branch Circuit(s).
(A) Grounding Electrode. Building(s) or structure(s) supplied by feeder(s) or branch circuit(s) shall have a grounding electrode or grounding electrode system installed in accordance with 250.50. |
| Quote: |
| 408.34 (A) Lighting and Appliance Branch-Circuit Panelboard. A lighting and appliance branch-circuit panelboard is one having more than 10 percent of its overcurrent devices protecting lighting and appliance branch circuits.
408.36 Overcurrent Protection. (A) Lighting and Appliance Branch-Circuit Panelboard Individually Protected. Each lighting and appliance branch-circuit panelboard shall be individually protected on the supply side by not more than two main circuit breakers or two sets of fuses having a combined rating not greater than that of the panelboard. |
| Quote: |
| 210.8(2) Garages, and also accessory buildings that have a floor located at or below grade level not intended as habitable rooms and limited to storage areas, work areas, and areas of similar use |
Aron Jacobs
Electrical Contractor
Electrical Instructor
North Carolina
| Ready Kilowatt wrote: |
| The main protecting the subpanel is in the main panel at the house no? |
Roy Cooke Sr.
