For newer home inspectors the subject of suspended concrete floor slabs is somewhat complicated, but can be broken down into a few basic types: (I am still tweaking this article)
Solid concrete slabs options with conventional reinforcing steel, i.e., bottom of slab is visible.
- Clear span concrete slab between foundation walls in both directions.
One-way slab – Where the length (L) divided by the width (W) is greater than or equal to two. The main reinforcing steel is placed in the short direction.
Two-way slab – Where the length (L) divided by the width (W) is less than 2. Main reinforcing steel is distributed in both directions. - Concrete slab supported on one or more steel beams anchored into the foundation walls. Longer steel beams may have intermediate steel columns for added beam support.
- Concrete slab supported on one or more steel or concrete columns (no visible beams).
PROBLEMS
* Cracks that leak (poor waterproofing)
* Rusted/expanding reinforcing steel
* Negative bending cracks over intermediate support beams
* Punching shear where support columns punch through slab
Concrete slabs poured on top of corrugated metal decking, with or without visible support beams.
- Composite vs Non-Composite design.
Composite steel forms typically are embossed which helps bond the concrete to the forms. The composite steel form acts as the main reinforcement for the slab. Only smaller temperature/shrinkage steel is place below the concrete surface.
Non-Composite steel forms are typically smooth and do not bond to the concrete. The concrete needs to be reinforced for bending. The steel forms do not provide any strength in the slab design
PROBLEMS
* Cracks that leak rusting the steel decking (poor waterproofing)
Clear span precast hollow concrete panels.
- With or without concrete overlay
PROBLEMS
* Reflective cracking if the joints are not grouted or joined properly.
* Leaks due to poor waterproofing maintenance.
* Debonding of slab overlay
