Go to smarthome. for lots of ideas
http://www.smarthome.com/060626r.html
Roy Cooke sr
Roy Cooke sr
Check this out also
www.x10.com
No, there is only one click at the switching device, which can be either in the switch you are pushing or in a remote relay. Now there is a new version called Insteon which uses PLCs and RF signalas, I don’t know if it repeats the commands multiple times at the same device or not.
Thanks guys.
From the way you have described the switching, it sounds like the light switch is on a “lighting control system”. These controls take a little time to activate. The GFCI protection will work quickly, and the controls will have a small time activation delay.
