Thermidistat.... what is it?
Originally Posted By: pdacey
I performed an inspection for a buyer about 2 weeks ago. One of my comments in the report was that the AC condenser was emitting a humming noise when it was idle.
The seller has just commented that they had something called a Termidostat (don't know if spelling is correct) installed on the AC which they explained is a variable speed fan than runs when the AC is off to keep the humidity level in the house down. Now if that is the case, wouldn't you hear the noise from this fan running inside the house? What I heard was outside at the condenser and coming from the area of all of the electrical connections and the capacitor.
I've never heard of a Termidostat and how could it remove moisture from the air if the AC is not running?
Anyone ever heard of this?
Slainte!
Patrick Dacey
swi@satx.rr.com
TREC # 6636
www.southwestinspections.com
Originally Posted By: rsummers
Are you sure it was not a Heat Pump? If it was and the stat was set to cool it could be the reversing valve.
The system was a heat pump but was not running when I heard the humming noise. The noise was continuous.
I'm more curious about this Termidostat thing. Anyone?
Slainte!
Patrick Dacey
swi@satx.rr.com
TREC # 6636
Originally Posted By: jsavino
Sound like a electrical hum from a relay or starting contactor hanging up.
termidostat ? not thermostat ?.
John
Two notes:
You're more likely to get a response if you are more specific in your subject line: Like - Termidistat - What is it?? Just like the guys asking for ride alongs would probably get more responses if they put their location in the subject line.
Correct term is thermidistat:
For more information on thermidistats try:
For answer to your question, look on Page 9 of this Installation Instructions PDF:
http://www.thermostatusa.com/pdf/CCPRHO1-B-Installation.pdf
Brochure
http://www.residential.carrier.com/products/thermostats/p_thrmdst.htm
Brochure
http://www.residential.carrier.com/products/pdf/np_thrmdst.pdf
Isn't it amazing what you can google up in just a couple of minutes.
Good Luck and thanks for asking a question that got me to look up something I didn't know all the answers for.
Erby Crofutt
B4U Close Home Inspections
Georgetown, Kentucky
www.b4uclose.com
Thanks Erby. Those links are a big help.
Now that I know what it is, could it be a possible cause for the humming out at the condenser? I would think not, am I wrong?
Slainte!
Patrick Dacey
swi@satx.rr.com
TREC # 6636
Originally Posted By: rwills
Patrick, Could it possibly be the compressor warming electrical circuit? This will hum if the unit has been off for long periods to warm the compressor. Was the unit being recently operated when you arrived or had it been off for quite a while?
Bob Wills - MAB Chairman
BW Inspection Services
Warminster, Pa.
http://www.bwinspections.com
Originally Posted By: jpeck
A Thermidistat is the thermostat / humidistat control for a variable speed fan Carrier a/c air handler unit.
The Thermidistat does the function of both.
The thermostat function operates the same as a regular thermostat.
The humidistat function runs the fan at lower speeds (because it is a variable speed fan) to keep the a/c running for de-humidification purposes without excessive cooling taking place.
This is accomplished by the a/c being turned on by the thermostat, the a/c satisfying the thermostat temperature setting, yet the air still having more humidity than the setting the humidistat portion is set to, so the fan speed drops to a slower fan speed and keeps running. This keeps removing moisture from the air, yet the fan speed is not high enough to provide additional cooling air to the living spaces (not to noticeably keep cooling it). After a programmed in number of minutes of continued operation, the humidistat section shuts the air handler off, having removed some additional humidity from the air.
This occurs after each time the a/c comes on, slowly satisfying the humidistat by getting the humidity down to the desired setting.
The main purpose of an a/c is to de-humidify the air, and this does just that, cooling as much as necessary, then continuing to de-humidify for a while longer.
Jerry Peck
South Florida
Thank you Jerry for such a detailed explanation.
One more question, when the blower reduces speed to de-humidify, does the condenser continue to run at full speed?
Slainte!
Patrick Dacey
swi@satx.rr.com
TREC # 6636
