House was built in 2014 in a new development. All single strand branch wiring appeared to be aluminum. My gut tells me it is probably tinned copper wire.
Have you seen this before? I called it out for review by an electrician to verify what type of wiring was used.
Need more pics and type of wiring sheathing, etc. NM or individual wires? What did the grounding conductors look like? The electrician may have gone the extra mile and just tinned the ends.
Appears to have soldering flux on it.
Seen it at an electrical engineer’s house.
Only way to tell is safely scratch with an electricians driver like someone mentioned above.
Verify your driver is insulated.
The image is from a 30 amp dryer circuit. It looked like an aluminum colored coating and was a little lumpy on the surface, not smooth like normal wire. It was 8 or 10 gauge.
