TIP SHEET - WATER HEATERS
Originally Posted By: jbowman
With this in mind, lets examine the various considerations we all should take before purchasing our next water heater.
What size or capacity will I need?
Small - Medium Home 1-2 people 40 gal. electric 30 gal. other
(1 bath, Clothes Washer).
Medium Home 3 people 50 gal. electric 40 gal. gas/propane 30 gal. oil.
(1.5 baths, Clothes Washer, Dishwasher)
Medium - Large Home 3-4 people 65 gal. electric 40 gal. other
(2 baths, Dishwasher,Heavy-duty Clothes Washer)
Large Home 5 people 80 gal. electric 50 gal. other
(2+ baths, Heavy-duty Clothes Washer & Dish Washer)
This scale is just a recommendation. Factors such as whirlpools, etc should also factor in and be weighed when making your decision. Check with your local professionals for more accurate sizing.
Types of Water Heaters:
Storage type:
The most popular for residential water heating. They operate by releasing hot water from the top of the tank when a hot water tap is on. Cold water is introduced to the bottom of the tank as hot water is drawn. These tanks operate on electric, gas, propane, and oil. Because the water is constantly heated with this system, energy can be wasted even when not being used. This is referred to as "standby heat loss". Consider tanks with at least 1.5 inches (3.8 centimeters) of foam insulation and energy efficiency rating shown on the EnergyGuide labels. Insulation is instrumental in the prevention of standby heat loss.
Demand type:
Also commonly known as "Instantaneous" water heating. This system significantly reduces standby heat loss and reduces energy consumption by 20-30%. With these systems you never run out of hot water. Water travels through a piping system within the unit, and either a gas burner or electric element heats the water on demand. The biggest drawback to this system is limited flow rate. Demand heaters provide hot water at a rate of 2 to 4 gallons per minute. More than adequate if operating hot water at one location at a time. However inadequate if two or more are operating at the same time (i.e. shower and clothes washer). For additional costs, demand heaters can be installed in parallel sequence allowing or meeting hot water demands for multiple faucets operating at the same time. Gas fired demand heaters tend to have higher flow rates than electric. You should note that some gas demand heaters operate with a constant pilot light, however, the amount of energy consumed by a pilot light is quite small.
Heat Pump type:
Electric systems that move heat from one place to another instead of generating heat directly in one spot. They operate in the same manner as refrigerators only in reverse. They can act alone with built-in storage tanks or as add-ons to existing water heaters. They have a high initial cost and require installation in locations the maintain a 40 degree or higher temperature yearlong. To operate most efficiently, they should be placed in areas having excess heat, such as a furnace room. They will not functions properly in a cold space.
Tankless Coil & Indirect types: (Operate off your home heating system.)
Tankless Coil - No separate storage tank is needed in the tankless coil water heater system. Water is heated directly inside the boiler in a hydronic (i.e. hot water) heating system unit. Water flows through a heat exchanger in the boiler whenever a hot water tap is turned on. During the heating season, the tankless coil works well because the heating system is used regularly. The system is less efficient during warmer clients when the boiler is used less frequently.
Indirect - Requires a separate storage tank. Uses the same method of heating water through a heat exchanger as the tankless coil system. However, this heated water then flows to an insulated storage tank (most carry a lifetime warranty.). This system is more efficient than the tankless coil because the boiler does not need to operate frequently. When an indirect water heater is used with a highly efficient boiler they combine for one of the least expensive methods of water heating.
Solar type:
Strongly dependent on the sun, solar water heaters if properly designed, installed and maintained can satisfy half to nearly all of a home's hot water demand. System designs are either classified as passive, active or direct. The initial costs are high but overall operating costs are significantly lower.
Passive systems operate without pumps and controls and can be more reliable, durable, less maintenance, longer lasting, and less expensive to operate than active systems. Active solar water heaters require pumps and controls to move heat-transfer fluids from collectors to storage tanks. Both systems often require conventional water heaters as back-ups.
A direct solar water heating system circulates water through collectors and is not appropriate or recommended in climates in which freezing temperatures occur.
Capacity & Rating Efficiency
Most consumers base their purchase on the size of the water heater. However, the peak hour demand capacity, referred to as the first-hour rating (FHR) and Energy Factor (EF) should be the major basis.
FHR is a measure of how much hot water the heater will deliver during a busy hour, and it is required by law to be listed on the water heaters EnergyGuide label. Gas water heaters have higher FHR's than electric units of the same size. It may be to your benefit to switch to a smaller gas unit. Please bear in mind that if you do decide to switch, other installations costs may be incurred. See the venting section below.
EF is the best indicator of a water heater's efficiency which is based on recovery efficiency (how fast heat is transferred to the water). In short or layman's terms, the higher the EF, the more efficient the water heater.
Venting
Things that you should be aware of especially if you are:
- converting to a gas or oil-fired water heater in an electrically heated home.
In this instance, since no chimney will be available, you have the option of installing a direct vent or power vented gas or oil water heater. Flue gases are extracted through the sidewall of the home.
- converting from an oil-fired water heater to a propane or gas model.
May require that your existing chimney or vent to be resized and the liner changed to maintain adequate draft to avoid condensation in the vent system. Alternatively, a direct vent or power vented unit could be installed.
- replacing an existing gas, propane or oil-fired water heater with a more efficient model.
Sidewall venting may be the only practical option because of the potential increase in condensation formed in the venting system.
- replacing an existing gas, propane, or oil-fired water heater with an electric water heater.
Electric water heaters require no venting. They are simple to install and can be located in many areas of the home.
Additional Important Note
Most municipalities require permits, etc. prior to installation/replacement of water heater systems. Consult your local code officials for details. As always if you feel uncomfortable performing any of these tasks, please consult a professional.
I hope you enjoyed this little tip. This tip sheet is distributed freely to NACHI members and guests. Feel free to copy and disseminate this information in any way you feel comfortable with. You can either credit the original author or adjust the content to facilitate your own business or organization.
This tip sheet was prepared as a general reference guide only. The author assumes no legal liability or responsibility for the accuracy, completeness, or usefulness of any information, apparatus, product, or process disclosed, or represents that its use would not infringe privately owned rights. Reference herein to any specific commercial product, process, or service by trade name, trademark, manufacturer, or otherwise, does not necessarily constitute or imply its endorsement, recommendation, or favoring.
Originally Posted By: Blaine Wiley
Good stuff, John!
Originally Posted By: phinsperger
I see a trend here. Hopefully we can expect more of these Tip-Sheets. Great idea John icon_smile.gif
Paul Hinsperger
Hinsperger Inspection Services
Chairman - NACHI Awards Committee
Place your Award Nominations
here !
Originally Posted By: jsmith10
HI organization.
Thanks for the post, best regards,
Joe,
Vice-President, Idaho Chapter,
www.NachiIdaho.org
Inspected as though my family are to live or work there.
http://www.Treasurevalleyinspections.com
