TPO Membrane under Composite decking
20+ years in the business and literally tens of thousands of homes, but this was a new one to me: I inspected a two year old home yesterday that had a large observation deck off of the upstairs bedroom. The deck was made of composite decking boards with both ends inserted into a steel I beam type channel on the two drain edges of the roof. The roof underneath was covered with a TPO membrane, had a center ridge running opposite too the length of the decking boards and was very low slope (I measured it at 0.1 in 12). My concern is that water was not draining adequately from the roof surface below the boards, and in fact, most of the decking boards were standing in water (Less that 1/4”, but still sitting in water). What are the potential issues here that I may not have thought of, and has anyone else ever seen basically a floating deck sitting on top of a TPO membrane?
I don’t know of composite deck materials decomposing in water, but I think that I would have written that up as not adequately draining. We don’t like pooling water on a single-ply roof either.
Morning, Jeff.
I have seen floating decks boards many times. Limitations comes to mind.
C-beam or C-channel are integrated into the roof system are to direct water flow.
The TPO under that systems would likely be referred by an engineer.
I would note Low slope pitch of the 'roof, not deck boards, combined with Standing water the day of the inspection requires further evaluation, and correction, by a licensed general contractor with inhouse structural engineer.
But that’s just me.
Good luck.
