A PEX fitting is an insert fitting. If your jurisdiction follows the IRC this fitting should be increased to a 1” PEX fitting. The discharge piping should also terminate towards the ground with a gap of no more than 6” and no less than 1.5 pipe diameters.
Some AHJs allow this. On one hand, water will only be going through that pipe if something is wrong with the TPR valve or the water heater. On another hand, the discharge point should be somewhere that is readily visible. On yet another hand, the discharge point in the photo is readily visible, if you happen to be walking by it. Of course, too close to that discharge point during a pressure release event could be exciting.
So, IF there is a floor drain in the room with the water heater, I would write up that the TPR discharge termination should be in the room where any water coming out is readily visible. If the room doesn’t have a floor drain, then I would defer to whatever the AHJ allows in your area. BUT, whether there is a floor drain or not, and whether your AHJ allows this or not, best practice is to have the discharge next to the water heater within 6" of the floor. The PEX is not a problem. The wiring is a problem.
Your illustration shows something that in 24 years, I’ve never seen, but that air gap creates the readily visible point in the room with the water heater to see if the TPR is discharging any water. Around here, no AHJ requires that.
Same here, but I have no issue with it. The only issue I have with it going to a drain pan is that many drain pans aren’t drain pans at all, but rather catch pans with no outlet. Here in GA, the tpr can discharge to the pan or the exterior, so I’m happy with either configuration.
