Is the galvanized, then flexible brass, then back to galvanized ok? IRC 2803.6.1 did not make mention but I seem to recall this being an issue.
Just realized that the pipe is going in an upward direction.
You are not supposed to link those water appliance connectors together either.
It’s just plain wrong.
Simply recommend a licensed Plumber to upgrade existing PTR valve configuration.
Definitely, recommend plumber / replacement.
