Tramex roof and wall moisture scanner. Purchased just under 1 year ago and in perfect condition. No scratches, nicks or dents. Comes with carrying case, strap, telescoping pole and original manual. Please see specs below if you are interested. Asking $1050.00 OBO. If interested please email me at randy@progressiveinspections.com. Happy to answer any questions anyone may have and send pics.
Details
**Features & Applications:**
Provides non-destructive moisture evaluation of roofs and EIFS (Exterior Insulation Finish Systems). Two sensitivity levels: low & high (deep) penetration. Roof and Wall Moisture Scanner includes a 9V battery and a telescopic handle.
Features:
- For tracing leaks into the waterproofing membrane back to the source
- Fast and easy to operate
- Instant clear readings
- “Hold” function facilitates ease of recording readings
- Lightweight hand held and battery operated
Applications:
Multi-mode moisture scanner for non-destructive moisture detection and leak tracing in the building envelope including:
- Built-Up
- Non-Conductive Single Ply
- Modified and Foamed Roofing Systems
- Exterior Insulation and Finishing Systems (EIFS)
Spec Summary:
Dimensions: 4.75”x 11” x 3”/125mm x 275mm x 75mm Weight: 1.8kg (4lbs) Power Supply: One 9 volt battery Sensitivity: Four ranges:
EIFS Mode with high and low sensitivity.
Roofing Mode with high and low sensitivity. Accessories: Leather carrying case. Telescopic
handle for use on roofing only.
