Vapor Barrier or Insulation?
Found this in a crawl today. First time I have ever seen it. It seems like some sort of vapor barrier or insulation. It was under the flooring throughout the entire house. It disintegrated into powder when I tried to tear off a piece. 1950s home. Does anyone know what it is?
It is/was a form of insulation but even when new probably wasn’t that great. I see it a few times a year and it usually looks about like that. I suppose there are also some vapor barrier qualities to it but my understanding is that the main function was insulation.
Looks like balsam wool.
Morning, Nick.
Sorry for the edit.
Low-Density EPS (White Foam Board): While rigid, this foam consists of expanded plastic beads that can break down into small, persistent crumbs or “goo” when exposed to extreme heat or certain chemicals like acetone.
Low-Density EPS with tar paper backer.
Just my 2 cents.
