vent tapping (posted by Donna)
[ASKNACHI]This question was posted on AskNACHI.org by Donna (from Santa Cruz Calif.). [/ASKNACHI]can u tap into a french hot water vent pipe?
What exactly is a French, hot water vent pipe?
Never heard the term either…nor has any search engine…Hmmm
Customize
Yahoo!
Suggestions:
  • Start typing to see suggestions.
Showing results containing:
Explore concepts: french hot water vent pipe +
Search Assist Settings
Help
Sorry, there was a problem retrieving search results. Please try again.
1 - 10 of 810,000 for ** french hot water vent pipe** (About) - 0.24 s | SearchScanBETA On
**WEB RESULTS**
  1. jwdanforth.com/webmodules/ServiceCategories/…
… styrine, a rigid black plastic pipe used for drain, waste, and vent lines. … Peak Hour Demand - Time when the largest demand for hot water is needed. …
jwdanforth.com/webmodules/ServiceCategories/…?id=51&serviceid=1 - 80k - Cached
  1. crab recipie?
… wrap, vent and microwave on high for 5 to 6 minutes or until sauce is hot and bubbling. … water for approximately three minutes. Drain and keep hot. …
answers.yahoo.com/question/index?qid=20070309041658AASzIB1 - 88k - Cached
  1. Mr. Rooter Plumbing of Calgary | Plumbing Glossary | Plumbing, Plumbers …
Its inlet connects to the water supply pipe in a wall, and its outlet angles up … incoming hot and cold water supplies by immediately regulating fluctuations …
www.mrrooter.com/calgary/plumbing/Glossary.aspx - Cached
  1. **venting: Definition, Synonyms and Much More from Answers.com](http://rds.yahoo.com/_ylt=A0oGkmhXGE5Iah8B9kdXNyoA;_ylu=X3oDMTEzaDI1c2FhBHNlYwNzcgRwb3MDNARjb2xvA3NrMQR2dGlkA0gxMzVfMTIy/SIG=11l98dd3o/EXP=1213163991/http%3a//www.answers.com/topic/vent)
An opening on the ocean floor that emits hot water and dissolved minerals. … by Old French vent, wind) of fente, from Old French, slit, from fendre, …
www.answers.com/topic/vent - 77k - Cached
  1. The Drain Surgeon/The Air Surgeon | Glossary/Terms
… styrine, a rigid black plastic pipe used for drain, waste, and vent lines. … Its inlet connects to the water supply pipe in a wall, and its outlet angles up …
www.thedrainsurgeon.com/terms.html - Cached
  1. Glossary - H. J. Pertzborn Plumbing
www.hjpertzborn.com/glossary.htm - 60k - Cached
  1. Plumbing Glossary - A Detailed Glossary of All Plumbing Terms and …
Time when the largest demand for hot water is needed. Pipe Dope: Slang for pipe-joint compound. … assorted pipes in a drain, waste and vent system; designed …
www.sandiego-plumbers.com/info/plumbing_glossary.htm - 55k - Cached
  1. homeimprovement.eyre.ca
Knocking Noise In Pipes. Knocking Pipes. Lack of Hot Water. Laying Pipe for French Drain Holes … in the vent pipe of the water heater (the pipe coming out of …
homeimprovement.eyre.ca/?SetSectionID=52226 - 111k - Cached
  1. Plumbing Definitions Glossary - A Detailed Plumbers Glossary of …
Its inlet connects to the water supply pipe in a wall, and its outlet angles up … joins the assorted pipes in a drain, waste and vent system; designed to allow …
plumbing.1800anytyme.com/info/plumbing_glossary.php - 94k - Cached
  1. Vpssinc.com Veterans World Wide Commercial Maintenance Services for New …
www.vpssinc.com/index/dictionary.html - 77k - Cached
Its a bong filled with french wine instead of water…
Dont you guys know anything?:roll:
en its ability to conform to fill any gap, blown foam insulation is a great way to fully insulate your home and maximize energy efficiency. Blown foam insulation will reduce air leakage in your attic and basement, and can even be blown into cracks along windows and door frames to ensure a seamless air seal. Adding blown foam insulation will reduce your energy use and energy bills and the material itself is eco-friendly! Blown foam insulation is primarily made with recycled content.</p>
<img src=“images/content/blown-insulation.png” alt=“blown in insulation” />
</div>
Gotta love the French
