I’m just training on HVAC now and it’s not an area I have much experience in, so I could be completely off here…
I’ve been looking at friends’ systems to get familiar with more of them and on this one, am I correct that there should be a vent tee on the side of the p trap closer to the wall?
Is the visible upper opening at the elbow supposed to be a vent or a clean out?
The opening in that elbow is a clean out, condensate pipes can get gummy and blocked up. Where does that P trap go? Condensate is not supposed to go into the waste system, although that might only be if the house is on a sewer?
Condensate lines are usually just gravity fed to the outside of the house above the ground or into a condensate pump which then pumps it to the outside.
With this setup I would guess that that p trap will get clogged eventually and there isn’t a clean out ( at least not that I can see) close enough to the trap to do anything about it without opening it up.
It appears to terminate near the exterior condenser unit. The p trap looks like the ones used in a lavatory… Most of the installation diagrams I’ve seen of condensate lines make a u trap out of pvc and put a vent on the downstream side of the trap.
