Ventilation
Inspected a detached carport and no attic access or ventilation was present. Vinyl was in ceiling and cornice. Seller was a builder and said no vents were needed. My question is, does this attic require the same amount of ventilation as house attic.
Donnie,
You are a member here. Please post your question in the regular Forums. This one is reserved for the general public’s use, and does not see as much use. Also, many of the standard features are limited, such as inability to quote someone and post pictures.
Also, please fill out you profile info in control panel above, as your location has an influence on the answer.
Thanks.
Btw… my first question to you… Is it an actual “Carport” or a modified “Garage”?
Pics would be great to help us as the design may affect the reply, but you cannot post them in this thread.
Jeff is right, you haven’t given enough details to give a certain answer, but maybe this will help.
Flat Roof without actual attic space? maybe.
Gable or Hip or other with an attic space? yes
Without vents the heat buildup will cook the shingles prematurely or snow melt could create ice damming on the north side(e.g. if gable roof with south and north facing fields).
If they have insulated a flat roof (no attic space) with a spray foam and the garage is conditioned then no, vents aren’t needed as it will be considered a hot roof installation.
Bingo
