Can a flue pipe be reduced from the draft hood like the one in this picture ?
The flue section of pipe is a ‘B-vent’ to assist in protecting the PEX from heat damage.
The internal pipe size is likely the same as the rest of the flue. You can verify this if you can get the numbers off of the label.
Non-issue IMO.
Looks fine!
what they said…
No I don’t, thanks for the info
