Water heater pipe connection
Afternoon fellow inspectors! I wanted to know if I’m correct about the WH exhaust pipe. In the photo is the pipe incorrectly sloped, and there shouldn’t be screws on the pipe connecting point… right?
Nothing wrong with the slope and screws are acceptable unless prohibited by the connector or chimney manufacturer.
For the screw issue you are maybe thinking the dryer vent as that is not allowed to have screws that can trap lint.
slope is fine screws are fine, was that top transition into the B vent installed far enough???
Yes, it was.
Thanks you all for the help!
then You look good from ohio sir !
Tape.
Tape on a draft flue is wrong, and won’t last.
And give that thing a good shake if you’re there, sometimes they’re not really attached.
