Originally Posted By: mcyr This post was automatically imported from our archived forum.
Kevin;
All you are doing when flowing the hose is verifying how much water the well pump is able to produce in one hour.
Did you determine the horsepower based on this input?
Their is no indication of how the well performed by your test other than the amount of water that you timed as gallons per minute.
When we take a water sample from a faucet, it is a standard to take the screen off and completely wash the spout and surrounds with alcohol. This is the standard way of disinfection. That also includes jars and holders for the water.
I guess my stand will be to advise anyone to stay away from well testing and leave it up to the people that do it for a living and know all about what the procedures are.
Originally Posted By: Brien Stratton This post was automatically imported from our archived forum.
Thanks for your answers gentlemen. It does help me. I have come to the conclusion that there is more to this well testing then meets the eye. It appears that a flow test/well inspection by a professional would be a wise thing to do.
I guess I spoke prematurely, and repent in dust and ashes...... was just trying to get some reaction (I guess it worked). Thanks again for the info. This forum can only be positive for your industry as the potential house purchaser can see the need for house/well inspections, so they can make a better decision on their purchase.
Originally Posted By: rwand1 This post was automatically imported from our archived forum.
Brien
I could tell you some horror stories about wells and how two clients of mine were taken for a ride by a local builder who has constructed or altered wells, resulting in losses of thousands of dollars because of his greed.
Need I remind anyone who lives in Ontario of the Walkerton fiasco?
Raymond Wand
Alton, ON
-- Raymond Wand
Alton, ON
The value of experience is not in seeing much,
but in seeing wisely. - Sir William Osler 1905
NACHI Member
Registered Home Inspector (OAHI)
http://www.raymondwand.ca
Re my horror story with two wells.
Last year I had the opportunity to inspect two rural properties, buit by a local builder who has a very poor reputation. Both situations are very similar if not the same, so I will roll it into one story.
Upon arriving at the properties I noted a bored well, grading around the well was poor. So poor infact there was a pool of water around the well head. Being a country boy and being familiar with wells solely from exprience and reading a lot of info I pointed out to my clients that the wells were not properly installed nor did they appear to be done by a licensed well contractor. I instilled upon the purchasers to check with the vendor (the builder) about the condition of the well on each property. Several months later I was contacted by one of the owners and informed that even though the builder had assured them the well was fine they took it upon themselves to contact the Ministry of The Environment, who sent an inspector out. The inspector looked at the well and told them the well was improper and must be abandoned and a new well drilled. Well $9K later, ditto on the other well. Both parties had already bought the properties only to find out subsequently the wells were no good. The second property had to drill a new well at approximately $9K too. These were unanticipated costs, and as a result the Ministry is taking to court the builder, and possibly the Realtors who have assisted this builder with his sales over the years. You have to appreciate this builder has a bad, bad reputation and builds new homes with salvaged material. I have inspected many of his homes for clients. It turns out the two wells I pegged as improper are not the only ones this builder has worked on or installed. So now its gone to litigation and I was interviewed and had to sign a statment of fact as to my findings to be used in the prosecution. As of this point in time the builder is still building and I have yet to hear from the Ministry of the Environment.
The purchasers never sought anything from me for their own misfortune.
Raymond Wand
Alton, ON
-- Raymond Wand
Alton, ON
NACHI Member
Well I did forwarn them before they purchased. Neither one came back and told me what happened, nor did the complain. I only heard about it when the Ministry contacted me looking for evidence.
This is another bored well, it has a gap in the top plate, which is big enough for mice, bugs, leaves to get into. How much do you want a bet the bacteria test comes back bad? Will be recommending a lic. well tech take a look at this.
-- Raymond Wand
Alton, ON
NACHI Member
The tree branch is hiding the gap. The gap is approx. 3/4 inch wide, because the lid is two piece. The top of the well does not sit well above grade. I would hate to think what could be in the water!
Originally Posted By: vfernandez1 This post was automatically imported from our archived forum.
Septic Tank inspection in California. Are inspection for septic tanks in California regulated by a certified inspector, and where can I acquired this information. In addition, how can I acquire; ?Private Sewage System? Septic checklist developed for ITA Inspection Training Associated, Kevin O?Malley.
