WH bonding
Are the water lines on an electric WH required to be bonded? I would guess yes, but just wanted to be sure.
Originally Posted By: Guest
The bonding can be anywhere, but at the tank is most common.
Originally Posted By: jmcginnis
They are required to be bonded if they are copper. in some towns in my area. It is my understanding that bonding them at the WH removes the possibility for “electrical potential (voltage)” between the hot and cold pipes. Would appreciate if someone else could weigh in on this question as to why the bonding is required and or recommended.
Originally Posted By: lfranklin
But what I’ve always heard was so when the water heater was removed, there would still be a bond between the hot and cold lines.
Originally Posted By: bbadger
IMO the NEC is very vague on this.
The metal water piping system shall be bonded is pretty much all the NEC says.
Some areas require a bonding jumper at the water heater some do not.
The mixing valve at a tub / shower usually makes a good bond between the hot and the cold.
The NEC handbook says this.
Quote:
If it cannot reasonably be concluded that the hot and cold water pipes are reliably interconnected, an electrical bonding jumper is required to ensure that this connection is made. Some judgment must be exercised for each installation.
Originally Posted By: smcintire
IRC 3509.6( metal water pipe bonding) The points of attachment of the bonding jumper(s) shall be accessible.
Kevin
The simple answer is that the hot waterlines "must" be bonded to the 'cold' waterlines.
Where they connect does not matter.
Mike P.
