Originally Posted By: rpasquier This post was automatically imported from our archived forum.
I see a fricking mess.
A dryer vent with a negative pitch, I see a post that looks like it is most likely in direct contact with the underlying soil, I see insulation hanging down, that needs to be put back in place, I see insulation that looks like it is in direct contact with the ground and will wick moisture up into the flooring, I see vapor barrier that should be cut off the post and layed on the ground around the post, because bare soil is showing and the moisture that wicks up the vapor barrier will rot the post. I see unsupported wiring that should at least have some sort of hanger to support it, same with the vent pipe, it should be supported with more then just duct tape.
That post really bugs me for some reason, and not just the fact that it looks like it is touching the ground with concrete poured around it to keep it in place, it's got wet spots on it, or at least moisture stains.
Other then that, it looks OK.....
There's probably more that I missed, but that's the major stuff that I see.
For some reason I don't think that this picture gives the whole picture here...LOL
