I’m used to seeing the green stuff. Any ideas?
Minor leaks Kenton…ooozzzzzing…
If it was my house I would try tightening the packing nut by the handle…or just replace the thing…if that didn’t work…
Corrosion, calcium mineral deposits I believe. ,
We call it scabbing over as Dale said dripping water. I would suspect that the water is very hard
Well yeah, it’s definitely a leak, sometimes corrosion seals them if they’re minor. I guess when they leak that slowly the chemical process is different. Usually they’re slimy green.
I like to poke at them a little, to see if it really is a leak…![]()
Then all hell breaks loose…
Hope all is well up there Kenton…!!!..and the SNOW is gone…![]()
Yeah, kind like holding an armadillo up by his tail, then looking a little closer to see what’s that thing puckering at the base of his tail? #-o Oh… bad news!
OMG…
Still snow above 6500 ft., peaks are pretty well covered.
Yep, most of us’ll take the burst pipe.
