Originally Posted By: ryoung2
http://www.nachi.org/bbsystem/usrimages/D/DSCF0199.JPG ]
[ Image: Corrosion Picture 2 ]
Originally Posted By: rray
Home inspections. . . .
One home at a time.
Originally Posted By: bgentry
Bradley S. Gentry
Superior Home Inspection, LLC
Harrisonburg, Charlottesville, &
Elkton, VA
www.superiorllc.net
Originally Posted By: rcooke
Roy Cooke Sr.
Originally Posted By: mboyett
Mike Boyett
Capital City Inspections
Austin, Tx
www.capcityinspections.com
| Quote: |
Excessive rust and corrosion on top of water heater. A typical cause of this type of rust and corrosion is storing leaking chemicals (Windex, 409, Spray & Wash, etc.) on top of the water heater; other causes or multiple causes are possible. Rust and corrosion can conceal small leaks, and continued rusting and corrosion can result in additional leaks or larger leaks. Recommend further evaluation by a licensed plumbing professional. |
One home at a time.
One home at a time.
One home at a time.
One home at a time.
| bkelly2 wrote: |
| It is a crummy water heater made with inferior material. |
One home at a time.
One home at a time.
Mike Boyett
Austin, Tx
Originally Posted By: tallen
| mboyett wrote: |
| Robert, take a look at the photos on this link below. I still think what you are seeing is definitely galvanic corrosion, especially considering the lack of other tell-tale signs that might suggest a chemical reaction. I agree that can be an issue, I just don't think so in this case.
http://www.corrview.com/tech_p_10.htm#Gallery%20I |
I have put the past behind me,
where , however, it now sits, making rude remarks.
www.whiteglovehomeinspections.net
30 Oct 2003-- 29 Nov2005
| tallen wrote: | ||
Great link!! Thanks for sharing  |
Roy Cooke Sr.
http://Royshomeinspection.com
