Why am i blocked from replying
anyone else get blocked from replying. several hours and still blocked. been a member since 2014 and a CMI. don’t understand how im new here
Unfortunately, the board system, depending on your trust level may limit the number of replies that you may post in a given period. If you are a brand new user, that number is fairly low. It’s done to prevent mass spammers.
yep, he joined 19 hours ago
If you remain active on the board, those limitations go away.
because you are new here
Not sure but try going into your messaging and walk through the discobot and get past the welcome badge. You should be able to earn the Basic badge which may open it back up for you.
Get to trust level 1 by…
  • Entering at least 5 topics
  • Reading at least 30 posts
  • Spend a total of 10 minutes reading posts
