The reason you get mold a inspection is that you will almost certainly miss something on your own. There are too many places where mold can grow unnoticed and unrestrained. If you are seeking a mold inspection by a professionals mold assessor stop!; do not look elsewhere INDOOR MICROBIAL SPECIALIST (IMS) staff are state licensed mold assessors, scientist and engineers with degrees concentration in chemistry, biologist, metallurgy, Mechanical and Civil engineering.
Visit: Why Professional Mold Testing Is Necessary Mold Inspect
How to Prevent Mold
If you want to stop mold growth in your home or business, you’ll need to keep the humidity at a minimum. If you live in a humid environment, you can use air conditioning as well as a dehumidifier to remove moisture from the air. You can also find humidity meters at home improvement stores that let you monitor these levels yourself.
Another way to prevent mold growth is with circulating air. Closing the bathroom door constantly only keeps the moisture in one place. The same goes for any enclosed areas like your basement and attic.
You may also encounter excess moisture due to something like a leak or water damage. Your best option is to fix any leaks, which is good for stopping mold as well as any potential structural damage.
After a flood, make sure to remove any carpets or fabrics that have been soaked. It also helps to avoid using carpets in places without a lot of circulating air.
For more information relative to Mold Inspections, Mold Testing and or Mold Assessment visit us at: https://www.homeinspectorusa.biz or https://www.indoormicrobialspecialist.com
We have offices in The Villages, Gainesville and Fort Lauderdale, Florida. 352-633-3591.
Our Home Mold Inspection Main Office is based in The Villages, Florida.
#moldinspectionsthevillages
#moldinspectionsocala
#moldinspectionsgainesville
#moldcommercialinspection
#moldtestingthevillages
#moldtestinggainesville
#moldtestingocala
