Wondering if anyone has any solutions for condensation on window interiors. Dual pane, vinyl windows. Outside temperature here in Montana currently is around 0. Can get to -30. Would a dehumidifier help?
Thanks, Steve
Yes an auto dehumidifier with a drain to laundry tub .
we keep out home about 40% in the winter and have a small fan keeping the air moving .
Loose drapes also allow air movement on the windows .
Works for us .
Thank you Roy
If your talking about condensation between the panes, replacement glass units is the only option… There are a few companies that say they can remove moisture, by drilling and putting vents, but I question their results/cost. Replacement glass is easy to order and depending on the size I get local or have shipped. Few things: make sure you get correct thickness and if there is a coating (low e) on the glass you have to match up since they are not all the same.
If you have condensation on the inner (exposed to interior) surface of double pane windows at 0 F, your indoor humidity is too high. A dehumidifier is treating the symptom, not the problem.
The problem is most likely insufficient air changes, that is, your house may be so tight that fresh air is not getting in and stale air is not getting out. For your climate (same as mine) indoor humidity when it is very cold (in other words normal :-() should be no more than 30%, 25% would be better. If your indoor rh is already less than 30% and you still have condensation, you have other problems.
Reduce your indoor rh by bringing in fresh air, install a fresh air duct that goes from outside into the return air duct, use or install a fan switch on your furnace, better but more expensive, put in an HRV. If you don’t have exhaust fans in bathrooms and kitchen install them, if you have them, use them as they are meant to be used, especially when condensation appears. If you don’t have any of this stuff or you prefer a sledge hammer approach, open a door and a window.
