Zinsco Service Disconnect Panel
I ran accross a Sylvania (AKA Zinsco) panel today at a manufactured home. The only breaker in the panel was the 200 amp main disconnect. Because there are no branch circuits, is there less of a safety issue with the panel. The panel was quite rusty on the outside, but it looked OK on the inside. Thoughts?
http://www.nachi.org/forum/showthread.php?t=2878
It looks pretty cruddy to me. I’d treat it like a Zinsco–defer it.
Am I missing something,… there has to be dedicated circuit breakers for the home in a sub-panel somewhere??
Yes. There would have to be a sub-panel since the service entrance panel contained only a main.
Are you saying you couldn’t find it?
Yes, there was a distribution panel. But it is not the panel in question.
Paul, I’m sorry but I don’t understand what you’re getting at about the dist. panel. What is the something that you are “missing”?
I don’t see much of a problem with this one in particular. There is only one (two-pole) breaker which is “locked” in place.
Based on the looks of everything, it doesn’t appear that anything has over-heated - i.e, no indication of poor or deteriorated connections at the bus bars (which is a primary problem with these panels).
I wouldn’t be real concerned with this one, but that’s just me.
