I know this is a defect because of the 2-3-10 rule. If the water heater flue (B-vent) were raised to be 2’ above the furnace (PVC), would there still be a defect? The water heater would draw correctly, and the furnace is sealed combustion.
If it would still be a defect, why?:roll: Both appliances would work properly.
(None of this is in the report - just wrote it up and recommended an HVAC contractor. Just for me.)
Excellent thread (most of it anyway). I didn’t get the meat of it the first time around, most likely because I read it as a disjointed series of posts, along with posts from other threads.
The main thing I got from the informative part was (I think it needs restated):
It is a common misapplication for code users to apply
chimney termination height requirements to vents, thereby
causing vents to extend above roofs much higher than required
in many cases.
