Is it a good idea to recommend to clients to update electrical receptacles to a 3 prong grounded outlet in living spaces such as family rooms, iving rooms, etc… to meet modern electrical requirements for cable,electronics,computers, etc… Also, has anyone used the Ideal circuit analyzer 61-165. i’d like to get some feedback. Thanks
Unless you are absolutely sure that each receptacle is able to be grounded, don’t recommend a replacement with a three pronged recept. An electrician may be needed to upgrade each branch circuit where a ground is needed.
Home inspectors call out defects. This system, unless observed in a new construction or addition, is not a defect.
Home inspectors do not recommend remedies to the defects that they point out in their reports. They recommend that they be repaired or replaced by a qualified contractor.
I will include a narrative that the two prong system is perfectly safe, will accommodate GFCI receptacles, and does not need to be replaced. I will mention the dangers caused by “adapters” and the possible inconvenience this system poses when using most modern day electrical appliances.
“Outdated” infers the need for replacement, which I do not recommend for anything that is not defective (with the exception of GFCI in wet areas).
2-prong outlets are not a defect. It is errant and misleading, on our part, to state or to infer otherwise.
I agree with James on both quotes! Unless you are licensed to make that call and never worry about liability issues, I would stick with what a home inspector should report. I often tell folks:
I am like the General Practitioner and the Plumber, Electrician, etc is like the Surgeon.
Everyone can separate the Doctor at the clinic and and the Surgeon at the hospital.
Not disagreeing with you Bob. Just saying I stick with more along the line of James’s approach. Never thought you said “defect” and yes it can be a defect in more than just new construction. I have wrote them up when they were defective but never simply because they were two pronged.
It’s not “ignoring the fact,” it’s observing the fact.
The fact being that these receptacles were never intended to be grounded, and as such, there is no reportable issue. Much like older 240V circuits that are wired with 3 conductors (H-H-G). Newer requirements mandate 4 conductors (H-H-N-G). Do you report on 3-wire 240V circuits?
Smoke detectors (same here) and 15’ from bedrooms.
Irregardless I recommend what is best for the home and if they update part of the electrical system such as GFCI not noted in kitchens or bathrooms then they must also by Law as you say update the entire system.
True or Not?
