As Home Inspector how do we check the 240 volt dryer outlet ?
Is there a tester similar to the device we stick into the 120 volt outlet
to check for correct wiring ?
David
David
Use your NCVD to verify two 120 volt contacts.
Same Here…
The wiggy (or similar device) is certainly more reliable and accurate, but the NCVD is quick and simple for determining if voltage is even present. . .
Agreed.![]()
it certainly is and probably all that is necessary for Our purpose…I just happen to have had the wiggy for a couple thousand years so i use it…just habit…
Thanks everybody…
With a Wiggy you will be able to verify grounding, with a NC tester you will not.
