Originally Posted By: jtedesco This post was automatically imported from our archived forum.
A 120/240 V, 3W branch circuit (neutral) is spliced here to ensure that its continuity will not be lost, that’s why it cannot rely on the terminals of the device, here that device is a receptacle.
Originally Posted By: Bob Badger This post was automatically imported from our archived forum.
jtedesco wrote:
It is always better to splice the neutral, even on a two wire circuit, because it has been known to cause fires when it comes loose after time and where the branch circuit was supplying a load.
For a 120/240 V, 3W branch circuit neutral I agree with you 100%.
I do not agree with you about the grounded conductor of a two wire circuit.
The grounded conductor of a two wire circuit has no more or less potential to cause a fire than the ungrounded conductor due to a loose connection.
You might say it is better to splice all conductors of a circuit, but that is not a code requirement.
Originally Posted By: Mike Parks This post was automatically imported from our archived forum.
IMHO
I do not understand why Joe's example is safe but if I put the other circuit on the same yoke it requires a "double" breaker. Yes I know that the above is code compliant, I just do not like it in a residential application.
This is one of the most dangerous conditions for the novice.
Originally Posted By: Ryan Jackson This post was automatically imported from our archived forum.
Mike Parks wrote:
IMHO
Mike P.
How is Joe's picture not safe?
If you show me somebody that doesn't know how to handle a multiwire branch circuit, I'll show you somebody that should keep the hell out of the box, novice or not!
