Reading your narrative, it is pretty obvious to me that you personally do not have any formal knowledge about electrical design nor installations. And that is okay. You are basically guessing and taking blind shots at these issues.
Most of our peers here are right when they express their doubts about the troubleshooting abilities of most “electricians” out there. What you need is a “State Licensed Master Electrician” either the understanding of How things should/must work to declutter the situation and restore the integrity of your electrical installation.
Many times these ‘behaviors’ are the result of improper wiring issues created by some uneducated person that, with the best intentions, got its hands on the electrical installation to fix something and misswired something else (reverse wiring, left an open ground or phase, who would know!?!).
Thank you, Pedro! The thing is, with both of these situations, they have worked well for years with no problems, so it’s interesting. I’ll be doing a deeper dive tomorrow. You’re right, I don’t have any formal training, but I do understand how a house is wired. This is an older house and it’s pretty basic so I’ll be tracking it all down amongst all the renter’s crap. No blind shots taken😉
How are you testing for “power”? Are you using a non-contact voltage detector? If so, these will not check for a lost neutral. I suspect that you lost a neutral, which testing line to neutral should confirm that. Follow @gwells procedure for checking which receptacle is causing the problem.
How old is your friends house? The reason I ask is that some older homes prior to about the late fifties, they used to switch the neutrals. Sometimes when you have an open neutral, a non-contact voltage detector may detect voltage. This may explain why “the power disappears” when you flip the switch ON. You may need to check line to neutral in the fixture outlet.
That does not mean you have electrical troubleshooting skills. In Maryland it simply means you are knowledgeable in the NEC for different wiring requirements. Basically it means you know how to find things in the current code. No-one can remember it all.
Robert, How are you? We need to get together sometime..!
Look, a Master Electrician not necessarily has “troubleshooting” skills, but it should! If you are a MASTER of any kind, you should/must have the right skills to do the job, not just the knowledge of the contents of the National Electrical Code (‘The Book’). But this observation is as good as it is for any profe, the Diplomat does not dress the Man. I am a College Grad Electrical Engineer, but what makes me a Master is not the Title, is the 45 years of the Street University as a “Field Engineer” surrounded by hundreds of other fellow engineers and technicians that shared their wisdom and expertise with each other. That combination is the MASTERPIECE, A) The Academy/Classroom + B) The Street Knowledge/Wisdom and(+) The camaraderie of sharing their experiences and findings in the field. That last piece is what I value the most from this InterNachi blog. You all, newbies and old farts..!
That’s not a requirement of being a master electrician. That is your, and my, personal opinion, but our opinion does not comport with industry norms. I don’t disagree with you that a master electrician should have troubleshooting skills, but that’s not part of the standard. If it were up to me, apprentices, journeymen, and masters would be required to learn more about how electrical systems work and how to troubleshoot.
The problem is that you and I cannot redefine a trade. As an electrician, I felt like my training was woefully inadequate. That’s why I went on to get a BSEE.
I also realized that troubleshooting skills are like musical skills. Some people have an aptitude for troubleshooting just like some people have an aptitude for music. Some of the best and brightest engineers can’t master playing a musical instrument. Likewise, some of the most talented musicians can’t understand electricity.
Electricians are mechanics first and foremost. I went through an electrical apprenticeship. The electrical theory wasn’t much more than was taught in electrical shop in high school. As an electronics hobbyist, I knew more about electricity before high school than was taught in high school. I did not learn anything more about electricity or troubleshooting in four years as an electrician apprentice. I learned how to bend conduit, how to look up stuff in code books, how to make good connections and other stuff that an electrician needs to know. That’s all.
I got my BSEE while working full time as electrician. I learned a lot of good stuff, but troubleshooting was not part of the curriculum. I learned and developed troubleshooting skills on my own.
So, while I agree with you that, in a perfect world, master electricians should possess troubleshooting skills, I accept the fact that reality is much different. Electricians are mechanics, not diagnosticians. You and I can’t change that.
