A "Dim" Witted Question
Originally Posted By: eharden
Hello all:
I conducted an inspection the other day that was a total mess. About the only thing that I did not find was a dead body in the crawlspace. My specific quandary is as follows: The very last thing that I did was one last walkthrough to make sure all the lights were turned off and that I had not left any of my tools behind. The last light I turned off was a regular
on/off switch controlling the overhead light in the kitchen. When I flipped the switch down, the light did not turn off completely. It dimmed down to the approximate output of a 25 watt bulb. My first thought was that it was some kind of dimmer switch, but upon closer inspection I found that not to be the case. It was just a regular on/off switch. This really concerned me because I have never seen this before, the first thought that popped into my little brain was “FIRE HAZARD”. Any idea as to what might be causing this? I reported it as a probable defective switch and advised further evaluation for that (as well as a slew of other electrical problems) by an electrician. I was so concerned about it that I left a note on the switch cover explaining what was happening and went into the basement and threw the main breaker before I left.
1.) Has anyone ever seen this before?
2.) Did I open myself up to liability by turning the main breaker off?
3.) Would I have been more liable if I had left a probable fire hazard in
place?
Eric Harden
First Choice Inspection Services
"That which does not kill me, makes me stronger."
Originally Posted By: tallen
The switch is old and starting to short out and must be replaced . I never turn breakers on or off.
I have put the past behind me,
where , however, it now sits, making rude remarks.
www.whiteglovehomeinspections.net
30 Oct 2003-- 29 Nov2005
Originally Posted By: Blaine Wiley
You could have turned the switch back on and unscrewed the light icon_biggrin.gif
No, bulb was incandescent.
Eric Harden
Now why didn’t I think of that Blaine?
Sorry about the florescent remark I was thinking of HID lighting with a capacitor .
Originally Posted By: phinsperger
on?
Paul Hinsperger
Hinsperger Inspection Services
Chairman - NACHI Awards Committee
Place your Award Nominations
here !
Hi all:
Thanks for the responses. It seems that I left out one important detail from my original post. That is that the switch was beginning to get hot to the touch. I noticed that when I returned to turn the light off.
Paul, I had to turn the light on when the inspection got to the kitchen.
Eric Harden
