A little help here?
Originally Posted By: jpope
Is there anything wrong with the location of this disconnect, or is it just me? eusa_think.gif
Jeff Pope
JPI Home Inspection Service
(661) 212-0738
Originally Posted By: Bob Badger
icon_rolleyes.gif It’s all to common, check this one out that has a sticker that tells you that the panel may need to be removed.
![](upload://aKwQQ78bMkeark4uCIwiWRK5BQX.jpeg)
Not that it isn't apparent the panel in your picture has to be removed, that must be the reason for all the flex. ![icon_rolleyes.gif](upload://iqxt7ABYC2TEBomNkCmZARIrQr6.gif)
Bob
Bob (AKA iwire)
ECN Discussion Forums
Mike Holt Code Forum
Jeff Pope
“At JPI, we’ll help you look better”
(661) 212-0738
Probably one of the reasons for the new 440.14 rule in the NEC:
Quote:
The disconnecting means shall not be located on panels that are designed to allow access to the air-conditioning or refrigeration equipment.
Joe Tedesco, NEC Consultant
www.nachi.org/tedescobook.htm
Originally Posted By: tallen
Mounted on the access panel? icon_eek.gif It is in within site though. I don’t know if its against code but, it sure seems like a bad place to put it.
I have put the past behind me,
where , however, it now sits, making rude remarks.
www.whiteglovehomeinspections.net
30 Oct 2003-- 29 Nov2005
Thanks Joe,
Now I do know ![icon_biggrin.gif](upload://iKNGSw3qcRIEmXySa8gItY6Gczg.gif)
Thanks!
Jeff: Is the thermostat wire in the same flexible metal conduit (greenfield or flex) that encloses the branch circuit?
If so, that could be considered as a violation.
300-3(c) = See 725.55(A) for Class 2 and Class 3 circuit conductors.
Mixing of the wires is not permitted! Very common violation!!
Yes, as a matter of fact it was. I didn’t know that was a violation. Thanks for the info, I’ll be submitting an addendum. icon_biggrin.gif
Another issue was that this was wired to two separate breakers at opposite ends of the panel .
240V with two throws required to turn off at its sub panel
I'll have that picture later.
Jeff Pope
(661) 212-0738
Jeff: See 240-20(b) in the 1999 NEC, or 240.20(B) in the 2002 NEC
Sounds very unusual! We have to discuss this type of circuit. The method you described is not one recognized by the electrical industry.
I believe that the original installation was not done by a "qualified person" or even an electrician. ![icon_question.gif](upload://t2zemjDOQRADd4xSC3xOot86t0m.gif)
Originally Posted By: jmyers
Jeff,
What size breakers is this air conditioning unit utilizing? Did you check the size of the breakers and wire?
I was just curious because most a/c units that I see are running off 30 amp breakers and single pole 30 amp breakers are not really all that common.
Joe Myers
This was a homeowner installation. He used two single pole breakers to obtain the necessary 240 volts for the A/C unit. If I remember correctly he used a 15A and a 20A breaker. “They didn’t trip too often,” so he said. icon_confused.gif
Notice he marked the panel A/C#1 and A/C#2.
This is not the service panel, but rather, a sub panel. Can you see what's wrong with this next picture?
The ground is connected to the neutral bus. This is the ground for the top left, 240V circuit (with the white handle tie). This circuit wire (Romex) ran the length of the home (about 30') to the electric clothes dryer. It was well supported as you can see in this next photo.
Did I mention, this is a mobile home
Jeff Pope
(661) 212-0738
Jeff,
Now we know who was burning down all those mobile homes that catch on fire and burn to the ground in less than 5 minutes. ![icon_biggrin.gif](upload://iKNGSw3qcRIEmXySa8gItY6Gczg.gif)
Joe Myers
