Originally Posted By: rmoore This post was automatically imported from our archived forum.
Besides the fine use of dryer lint for packing, we also now have no cleanout for the sewer. Pity, as this area later turned into a small lake when the sewer and floor drain backed up after testing all the plumbing fixtures.
The ABS is from the kitchen sink and the washer standpipe. Assuming things were in better condition, is there any way of making this connection legally without cutting up the cast iron stack?
-- Richard Moore
Rest Assured Inspection Services
Seattle, WA
www.rainspect.com
Originally Posted By: John Bowman This post was automatically imported from our archived forum.
Dependent on the condition of the cast "Y". If it will properly accept a male adapter where the clean-out plug used to be located, yes it can be modified legally. Materials needed:
1 - male adapter. (4" if it fits, 6 to 4 adapter otherwise)
1 - length of pipe.
1 - 4"x1/1/2"x 4" tee.
1 - clean out plug.
1 - glue
1 - cleaner.
Originally Posted By: mpalmieri This post was automatically imported from our archived forum.
The best way to fix that would be to get a 6"x2" or 4"x2" SV Hub & Spigot reducer with gasket, manufactured by Tyler Pipe. Then a 2" or reducing 2"x1 1/2" No-Hub coupling to connect to the pvc.
