Inside residential house service panels, I often see the neutral bus is bonded to enclosure( bya metal strip or by a brass screw), I can see Grounding bus screw to the enclosure. However, I rarely see the neutral bus is bonded directly to the grounding bus , such as by a wire,
do they have to be bonded each other or only a choice?
