Hi there! I’ve examined the basement’s distribution system in a 1959 home, and it appears to be the only problematic area. There’s an active leak, and significant corrosion is visible. Apart from suggesting immediate further assessment, do you have any additional advice or recommendations to include in the report based on these pictures?
Reusing OLD manifolds are never advised. They need replaced NOW!
If this is the same 1959 home as the Roof problems, the RED FLAGS are obvious for all other systems to be evaluated in depth by qualified tradesmen/women!
It does not need further assessment. It needs corrected.
Exactly…
Just fix it!
