Originally Posted By: jpeck
| Ryan Jackson wrote: |
| Jerry: Explain why there is a fine print note to 200.6 in the 2002 that says gray was an ungrounded conductor if Greg is so wrong. |
Ryan,
Welcome to the discussion, however, it seems that you have missed some of my comments.
"This is a case where past practices IN SOME AREAS (it was not done all over) conflict with normal practices (i.e., using gray as a hot instead of a neutral conductor)." and ones like that.
Now, I will change your question around for you.
Explain why gray is an approved color for use as a grounded conductor in 200.6 (not in the unenforceable FPN, but in the enforceable code section).
I went back to my 1935 NEC (the oldest one I have). They use "identified conductor" as the term for our "grounded conductor". The conductor we are discussing.
Ryan, if you would, please explain why, even back then, the code said this about grounded (neutral) "identified" conductors.
602. Rubber-covered wire
f. Single rubber-covered conductors No. 6 and smaller intended for use as identified conductors of circuits shall have the outer covering finished to show a white or natural gray color. (Then it goes on to state that cables with two or more conductors must have the identified conductor be white or natural gray.)
I'm all ears. (Okay, Ross Perot was all ears  I'm just listening for the explanation as to why you and Greg think that some local practices, warned about in the FPN, make it "legal and right" for all installations and gray being used for the neutral and grounded conductor is wrong in all installations, even though that use for gray has been in the NEC going back to AT LEAST 1935.)
Jerry Peck
South Florida
