Peerless oil fired boiler s/n 420231-200301 ,Thanks
As you can see from the number of responses, Peerless is one of those problematic brands. I don’t have any idea, either, but if I had to guess, I’d go with September 2002.
That was manufactured in** January of 2003**
Peerless
[FONT=Verdana]Prior to 1984 there was not a date code included as part of the serial number. After that, there was a four digit date code following the serial number that was month and year. Example – JO-12345-1084, this unit was built in October of 1984.
Starting in the year 2000, same idea only it was a six digit date code following the serial number that is year and month. Example – 1234567-200105, this would have been build in May of 2001. Anything without the addition to the serial number would have been made before 1984 and would require contactwith the factory.
[/FONT]
Thank you, David. More information for my research.
Thanks for this info.
