Aluminum wires?
Is this aluminum wiring?
Yea… Multi-strand is no concern… It’s the solid from the 70’s that you need to write up.
That looks like tin plated copper conductors not aluminum. They used a tin coating between the copper and the rubber because copper reacted with the rubber insulation. The conductor should have a R in it’s type. Likely RHW.
Thanks mark as always
I agree with Robert, tinned copper.
Thanks again everyone for the help
Tinned copper. . .
Oh you guys are to quick
nice handle-tie…
Jeff
Copper clad stranded. Even actual alum solid for other than branch circuts is ok. Used here all the time for water heaters, A/c units. Stranded alum. is used these days for main feeds also.
The copper wire clip used on the 15 amp and 2o amp seperate breakers Might be a concern though.
Mark are you saying that this is copper clad aluminum?
I would still agree with Jim and Jeffery, tinned copper.
