Comment Removed By Author
No, that is not “a normal home inspector’s experience” from my perspective.
Do you have a signed inspection agreement with your client?
Have you been paid for the inspection?
Was your client at the inspection?
Have you reviewed the report findings (material defects, etc.) with your client?
Does your client have the report?
What has been the exact communication with your client to date?
Will you share with us your report’s material defects exactly as written?
Sounds like a typical Monday.
Is that credible feedback? IMO, you should include one or more photos associated with every comment in your report. I add text under each of my photos with at least “Location: XXXX” or “Numerous locations”. Often there is more text when for example, numerous deck issues are grouped under one comment. I also circle or place an arrow pointing to the issue. Your primary job is communication - make it clear for a 10 year old. “A photo is worth 1000 words” applies to a HI Report.
Can we see that part of your report?
Realtors tend to think every house they sell is perfect. They can take it personally when you find a bunch of defects. Not a very professional attitude.
Your description makes me think this house was a ‘flip.’ They buy older homes and make a bunch of cosmetic upgrades to hide problems. There are a few good flips but it is not typical. The CSST behind drawers tells me this was not a good one.
As others have pointed out a photo for every defect is always needed. The days of reading comprehension are over.
May I ask what report software you are using and if you are using the built in template?
You should always write your own narratives. My report contains about 10,000 comments covers just about any defect you will come across.
So how exactly is this a material defect? Sound like a typical defect found in older homes.
What were the other “material defects”?
The only way we could give our opinions on if the agent is correct or incorrect is if we saw the report.
Sounds like you got some feedback. Good.
Take good, clear photos, especially of defects. I usually have a macro shot (orienting) and a micro shot (detail), along with any additional supporting photos with annotations. Make your narratives follow a detailed format. In NC, we call it DDID:
Describe: Describe the component or system of concern specific to the property inspected. For example, the exterior covering components of a home such as brick veneer versus vinyl or wood siding. Describe the location.
Determine: What is wrong with it? What is the defect, malfunction, failure, or performance deficiency?
Implication: What can happen if the defect is not addressed? Can it get worse? Will it injure someone? Is it a safety concern?
Direction: What should be done? Should it be repaired? Should it be further evaluated by a licensed professional to determine if action is needed at this time such as repair or replace? Should it be monitored over time?
You have the curse of knowledge because you were there and up close. Document the house in a way that someone can make sense of things without having to be there. If the agent or client is confused by your report, it’s probably your fault.
No.
Looking at your website, I can see you’re a minimalist, a man of few words. You said that the house was filled with defect after defect but the realtor said your report lacked detail. That tells me you probably skipped the WHAT, WHY, and HOW and your report was just a list of defects. That doesn’t cut it at $500 or whatever you charge for an inspection.
Hopefully you’re not one of those guys who thinks that there’s a direct relationship between your fee and the time it takes on the home and your report so you rushed this one.
My favorite part is “The client will not return any of my communication attempts”, he then does not respond to any of the questions and deletes his post.
Was the original post a question or a rant?
This is an example of someone so far behind in the race that they do not see any of the other competitors. And when they realize this they quietly remove themselves from the competition.
Tom,
You know you are over the target when you begin taking flak. Take it in stride and get used to it. The Realtor’s want you to write soft reports so that they don’t lose their commissions.
No one wants to hear they might actually be the one responsible. lol.
Getting better is part of the process.
Even after 12 years, if I look at report from 6 months ago, I think “what is this crap? We’re so much better now…”
Completely agree with you.
It can be difficult to find the balance when writing narratives, so it is ever evolving. I have taken the approach to write narratives as if the buyer has never touched a tool in their life while keeping it simple as possible. It is not perfect, but I have had very few questions over the last 18 years for further explanation. Kind of telling time without describing how to build a watch.
Only on here, we would argue with each other over what time it is for where we are located. That and turning it political over the Sunlight Protection Act.
That’s funny and so accurate for me, I do but I hate looking back at my reports
