Another Gem from our resident "lurker"
Originally Posted By: gbeaumont
whats wrong with this installation ?
Thanks again Richard.
regards
Gerry
Gerry Beaumont
NACHI Education Committee
e-mail : education@nachi.org
NACHI phone 484-429-5466
Inspection Depot Education
gbeaumont@inspectiondepot.com
"Education is a journey, not a destination"
Originally Posted By: dfrend
Daniel R Frend
www.nachifoundation.org
The Home Inspector Store
www.homeinspectorstore.com
Originally Posted By: jbehling
![](upload://7xKgdgV8pUgLPgFrgZFOndSfAk5.jpeg)
Gerry
What's right with it ? Holy @#$#%
Originally Posted By: kdemski
pipe wrap adds that “professional touch”…
Originally Posted By: psisler
Looks like the homeowner finally got tired of paying for a real plumber.
Originally Posted By: rray
Folks, there is nothing wrong with this installation. If you’re thinking that it is a standard water heater, it is not, as evidenced by the plastic irrigation pipes. This is a fertilization/irrigation system. Here’s how it works. Solid fertilizer is mixed with the water and is then heated by the water heater. Since hot water dissolves materials more easily than cold water, the fertilizer dissolves. Then when the irrigation system is turned on, the water is already full of appropriate fertilizers. This type of system typically is used for above-ground vegetables only, not fruits. Vegetables, like tomatoes (although a fruit), okra, string beans, etc., have thinner skins and can easily be damaged by solid fertilizers in the hot sun. This type of system prevents skin burns, which really turn people off in the produce section of the grocery store. I have the patent on this system. icon_lol.gif
Home inspections. . . .
One home at a time.
Are you bored today? You need to work on your marketing…get to it! nachi_sarcasm.gif
Definitely not bored. I just don’t get to stay in the office that often. We’re doing condos today, so I’m here working on reports, marketing, and, for a change, reading things outside the Members Only area.
One home at a time.
Originally Posted By: wpedley
What is this…it was hooked up to the boiler
system...I know it is the hot water system but I need more
info..name brand...Variant
[ Image: http://www.nachi.org/bbsystem/usrimages/more/photo%2015.JPG ]
BPedley
Inspecting for the unexpected
I had one of those about a month ago. No manufacturer information was available on it, so I don’t know. I did like the design of it, though. Much nicer than the standard water heater.
One home at a time.
Originally Posted By: Richard A Baxter
The next sad part is this one W/H served four units.It appears to be a lower end big box store W/H bet it has the 2500 watt elements.Which means it probably takes 1 1/2 to recover from one shower.
Without plumbers the world would have more crap to deal with.
Originally Posted By: jsavino
Looks like a indirect fired water heater. Using a zone off the boiler that circulates water through a coil in the tank to make domestic hot water. There should be an acquastat control inside the jacket to adjust water temp. which turn on the circulator pump.
John Savino
HomeWorks Inspection Services, LLC
St. James, NY
631.379.4241
