Another TPR question edited
Originally Posted By: rpasquier
This is VERY questionable to me, this is a rubber hoes coming from the Valve to the floor. Is this acceptable or should I recommend that they replace it with a copper pipe?
The image wouldn't post for some reason, so here is a link. click the word "link".
Here is a better shot of it.
First time EVER that I have come across a rubber hose used for this..
It is literally a soft rubber garden hose that leads down to the floor out of the TPR valve.
Thanks..
Originally Posted By: jpope
Can’t see the picture but the pipe is required to be listed for TPR application.
Jeff Pope
JPI Home Inspection Service
“At JPI, we’ll help you look better”
(661) 212-0738
Originally Posted By: rwills
Jeff nailed it! Not only would you get scalded, you would get 50 lashes from the pressure whipping the hose around! eusa_doh.gif
Bob Wills - MAB Chairman
BW Inspection Services
Warminster, Pa.
http://www.bwinspections.com
Originally Posted By: ekartal
Erol Kartal
ProInspect
Originally Posted By: tallen
moved
I have put the past behind me,
where , however, it now sits, making rude remarks.
www.whiteglovehomeinspections.net
30 Oct 2003-- 29 Nov2005
The pipe is supposed to be temperature rated for use as a TPR drain pipe, flow downhill all the way to an open air discharge. No traps, no rubber hose.
Erby Crofutt
B4U Close Home Inspections
Georgetown, Kentucky
www.b4uclose.com
Originally Posted By: hgordon
Here is how I would call it:
"Unsafe/Improper installation at Water Heater TPRV. Product not approved for application. Used approved heat rated material and plumb to an area that would not cause damage to owners belongings incase of a discharge."
Also, did you call the lack of a drip pan. Note a drip pan is required where owners belongings may become damaged in the case of a leak. Seems to me that there may exist that possibility.
Harvey Gordon
SE Florida NACHI Chapter - President
hgordon@fl.nachi.org
